Maybe they've fitted an RCD that's too small for the load, too close to the actual current draw.
I was just about to suggest the same thing !.
When my Rolec was first installed by the EV installer, they tested the unit correctly.
But only two days latter, it started tripping the RCBO in the the wall box randomly.
It would even trip the breaker when the car was NOT even plugged in !.
The EV installer returned after only four days of first install and replaced the so called new breaker with another unit supplied by Rolec.
All was fine, faulty breaker in the new unit was the cause of the random trips.
The poor quality of these Rolec branded RCBO’s have been well documented on the the forum.
With regular use charging at 7kw’s these breakers will only last about 12 to 18 months, before burning out ( usually) at the negative conductor.
Ask me how I know !.
It is NOT a termination issue, it is a failing of the internal components of the breaker unit itself.
Now the warranty on my wall box has expired, I have deceived to install a “Garo” branded RCBO instead.
Hopefully this unit will prove to be better than the Rolec branded breakers.
Time will tell I guess !.
