David
Hi there, I purchased my MG ZS EV in February this year, but I could not use my Huawei P30 pro New Edition with the navigation. Can anyone please let me know how I can work around this. Thank you
if you havent got google playstore on your phone as standard you can install it,just look on the web how to do it, same issue with amazon tablets but installed 4units with google play ok..Need to give more information what are you pluging in and where. What happens on the head unit when pluging in.
Best to use original cable as not all work with data.
Plug it in the port closest to the driver.
Your will need Google services, playstore and maps installed some Huawei devices don't have them.
I have an Honor 8X and had the same problem, I had a battery extender case fitted on it, the battery case did not allow data transfer which I did not realise after I took the case off it connected no problem, I believe some cables give the same problem so I would check with a cable that is guaranteed for data and charge, mine had android auto installed on the phone, make sure your phone has android auto installed, good luck with it.Thanks for your responses. I followed all the instructions I need to, but not luck. It keeps telling me to 'please connect an Android phone to the car with a USB cable using Android Auto'. I downloaded Android Auto, still it did not work. Meanwhile, my wife's iphone worked with the navigation. I will appreciate if anyone whose p30 pro New Edition works with the navigation can let me know how they did it. Thank you
I have a P30 Pro and have EXACTLY the same problem and error message. Try as I might I can't get Android Auto to work with the P30 Pro I've tried the original cable and cables recommended on different forums with no success. I've given up now and will wait until I'm due another phoen in March 2022, when I'll get a different make.Thanks for your responses. I followed all the instructions I need to, but not luck. It keeps telling me to 'please connect an Android phone to the car with a USB cable using Android Auto'. I downloaded Android Auto, still it did not work. Meanwhile, my wife's iphone worked with the navigation. I will appreciate if anyone whose p30 pro New Edition works with the navigation can let me know how they did it. Thank you
