How to use fan without turning AC on.
Simple in the screen for heating just press and hold the A/C round button on top row until it goes from green to white and the A/C is then off then select the bottom round button to switch and press and hold until green and air will go to screen and feet. If you at any time you use the short cut de mist button it will switch the A/C back on.
if you wish this setting each time you need to do this setting, you do know having the A/c on when de misting it will work faster taking the damp out of the air.
Thanks very much for your well explained answer to my question just got the fan speed set to 3 now and this keeps the car nice and clear. Thank you, Jeff
