I wonder if we will reach a point where ownership of a EV will be dependent on having solar panels on your home to charge it and or help support the grid.
I'd say not.I wonder if we will reach a point where ownership of a EV will be dependent on having solar panels on your home to charge it and or help support the grid.
Thatched roof with solar panels.It is interesting that there is such a backlash against solar farms. (Though I wouldn't be surprised if it was largely astro-turfed by the fossil fuel industry)
The critics say "we should put panels on rooves and car parks and not fields."
I always ask if they have panels on their own roof and that seems to shut them up.
I don't think the government is likely to mandate anything so specific and fiddly.
However, it is possible that houses in the future will be asked to have a certain minimum energy efficiency rating or face some sort of penalty (like not being able to rent it out or something).
Solar panels, EV chargers and batteries might be offered as a way to get energy home ratings up and so it might be strongly incentivised at that point if my imaginary suggestion ever happened.
But some houses won't be suitable for solar - what if you are next to a large block of flats with no sun getting through? Or are surrounded by tall trees? Or you have a thatched roof?
Sure, but it would be unreasonable to demand it for all. Particularly if they need some expensive solution which only captures a tiny amount of energy.Thatched roof with solar panels.
Of course, most won't be able to have them, especially if they are grade 1 or 2 listed. As to wooded environments, you can still use them; it's just the efficiency drops. And efficiency is improving. There is even research on 'solar' panels that work at night to generate electricity.
Just a thought that we might get to a tipping point where we need to put energy into the grid and perhaps if you can do so you will get some sort of preferential treatment? when to comes to owning an ev rather than a hybrid.It is interesting that there is such a backlash against solar farms. (Though I wouldn't be surprised if it was largely astro-turfed by the fossil fuel industry)
Like it, what a good idea.I'd have thought V2G would be a better mandated idea. Come home a plug in, let the grid use the energy in your battery to help with early evening peak loads, then replace the energy (and recharge) overnight when the wind turbines are still turning rather than turn them off to balance the grid. Solar is only useful if you can use it immediately (or have battery capacity to store it).
Sadly not so simple.. as the min charge rate for type 2 AC charging is 6A - and you'll need a battery buffer for when clouds pass overYes I wouldn't mind a car port or garage or similar with a couple of kilowatt solar just to trickle a bit into the battery.
Our transition to the MG4 was via two Gen 2 Prius, one with an extened range battery added and the other an ex taxi with 650,000 km on the clock when we bought it.I have a very black and white opinion on Hybrid cars. There are the worst of both worlds.
When you are driving on ICE, you carry the electric motor and battery as additional weight. When you are driving electric, you carry ICE as additional weight. How is this a good solution?
I think it is a case of putting them everywhere.Personally I think putting solar panels over car parks is more sensible than covering our fields. I see the following benefits;
Keeping cars underneath cool in the summer,
Protecting cars from the worst of winter weather,
If tiled with local batteries they could provided local (ish) EV charging or localised grid support,
Before anyone asks, I have two solar arrays, one Powerwall, two EV's and two motorcycles.
