Interesting... I admit to a little anxiety. So far I have driven my 5SR only around the Isle of Wight, and have been very pleased with the range achieved. Various ways to estimate, but I seem to be getting somewhere between 220 and 240 miles to a full charge equivalent. I think this is due to relatively short journeys at relatively low speeds. At the moment, the warmer weather is giving me 4.6 mpkwh, so potentially around 4.6*48.8 = 224 miles or thereabouts. This seems to be consistent with other ways of calculating. Hopefully I can keep up this rate .......
........However I am shortly to undertake 2 longer mainland journeys, and these will be trips into the unknown as far as range is concerned. It appears from various reports that I can expect only about 180 miles to a full charge (due to driving at higher speeds over longer times?), so I need to plan carefully. The first is a round trip of approximately 240 miles, via Wincanton, Cheddar area and Bath before coming back home. I see from Zapmap that there are a couple of Instavolt/Osprey chargers in Wincanton, and a couple in Shepton Mallett. I plan to top up at one of these (distance from home to Wincanton is about 90 miles and to Shepton Mallett about 120 (via Wincanton) so I should have plenty "in the tank" if I charge to 100% before I leave home), before visiting family. Hopefully one of these will be working. If neither of these work I can granny charge at my daughter's house, and then will have enough to get me the 120 ish miles I need to get to Bath and home again. However I do see that the Bristol area generally does not appear to be well served with Instavolt/Osprey/Gridserve/MFG chargers, which I gather are the most reliable and accessible. This will be my first foray on a longer journey and hopefully will pass off OK
My second planned excursion is a straight 200 mile journey to mid-Staffordshire, and return, this time with a full carload of 4 adults plus holiday gear. My intention is to charge at Banbury (130 miles from home) and then to top up again at Hilton Main motorway services or at West Bromwich (Astle retail Park), and again at Banbury on my return leg. The distances all look very comfortable, even if the range is only about 180 miles.
If I do get the 180ish miles from a full charge, then my plans for these journeys should all be OK, but as they are trips into the unknown, it will be interesting to see. As I said at the outset, I do admit to a little anxiety. Cross fingers....
