Mach13
Got my home charger installed today and was surprised that my HS PHEV Plugin only charges at 3.5kw
PHEV owners Is this correct?
Thanks ..its amazing just how many websites seem to give false information on charge rates... Like this one at Pod-PointYes
the on board charger is a 3.5 Kw so you will save a small amount of time on a charge from empty. You charge to full in about 4 hours on a 7KW, a granny charger takes around 6.6 hour.
Got it...It can only draw 3.5 KW from your wall charger. It was the time it will take to charge on the 7KW to a 2.2 KW granny charger.
Needed to get my meter tails and main fuse upgraded...Which was for the most part totally free. UK Power did the main fuse upgrade...(60 to 100amp) MY energy supplier upgraded the meter tails and mains switch install.. so just needed a couple of tails between the new mains switch and my meter to add to the cost...Did it cost a lot, also did you get the grant, what did you have fitted? If you change up to a Full EV you will have a charger for it.
FYI Not sure what the problem is hope its summat of an easy fix.. will ring em tomozEDIT: Suddenly having problems with scheduling... Wont go into schedule mode at all.. Will see what support say
Had to use a fair bit of petrol Friday and today. Luckily I was near an Asda and topped up for £30Are you glad you got a PHEV now with petrol as it is.
Yup.. just wish I didn't have a 450 mile round trip to make this week tho..Are you glad you got a PHEV now with petrol as it is.
I been up to Sheringham to day from Blofield Heath all the way then charge for free at Tesco and all the way back to Blofield heath on EV. Got some petrol at Wroxham for the home ward trip.Had to use a fair bit of petrol Friday and today. Luckily I was near an Asda and topped up for £30
Spoke to support (answered quick and v helpful) seems its a known issue with a recent update.. although the app shows the car stuck on 'preparing' it does actually charge as per set schedule. Tested and it did work.FYI Not sure what the problem is hope its summat of an easy fix.. will ring em tomoz
Yes correct they will only charge upto 3.7kwhGot my home charger installed today and was surprised that my HS PHEV Plugin only charges at 3.5kw
