Is there an outside temperature display?
Micropop
Mo i Rana, Norway
MGS6
Couldn't find it while out driving the other day. Didn't go through all settings, but could only find the weather forecast on the 2nd page of the main menu
Not as such. Outside temperature shows at top left to right of time on Home Screen
Did see that one. Must be a bug with mine then, as it showed the same temp as the forecast on the 2nd page, and didn't change even though the outside temp had changed at least 5 degrees.
Given your location could it be a case the actual sensor is frozen?
