Data
- Feb 20, 2025
- Essex, UK - Mk2 MG ZS Long Range Connect
- ZS EV
Yes, it's seems a bit contradictory. But the damage/degradation the battery experiences by NOT doing a regular 100% full & proper equalisation is much worse than if you do it. NMC batteries are not fragile although that's the impression we can sometimes get from reading some stuff that's out there. We know NMC doesn't have quite the same life cycle as LFP but the reality is it isn't ever going to matter to 99.9% of people especially if you look after it a bit, or even if you don't. I've calculated my NMC battery will last over half a million miles & probably 20+ years the way I use my car & charge it. You can charge them to 100% as often as you need to. The operative words here are 'if you need to'. I equalised to 100% during last week as I had a trip to make. Doing so gave me an estimated range on the GOM of 310 miles in normal mode. Of course, I didn't get that as I was driving on motorways mostly. But range was good. Ambient temp was 7C. It's surprising how range is improved by doing regular equalisation & calibration at 100%. And it's only every 5-6 weeks for me. That seems the sweet spot the way I use my car.I have to say, that I do find MG’s advice on charging and balancing for NMC type battery chemistry, a little bit contradicting myself ?.
On one hand they tell you to carry out a balance cycle about every month, right okay.
Then go on to recommend that charging to 80% SOC for your “every day” shorter trips, is encouraged for the “long term health of your battery”.
Save charging to 100% for when you are making the less frequent longer trips folks is the word.
Well we know that NMC batteries only perform a “correct” balance cycle, when commencing from a low SOC, then the balance cycle will start, only after the pack has reached 100% SOH.
I struggle to understand just how these two recommendations align then really ?.
Can’t see how you are expected to observe the advice of charging to 80% AND follow the instructions on balancing the pack every 4 - 6 weeks, which necessitates a 100% charge and some more.
The advise on LFP packs is much more simple, use it and then plug it in when you get home.
Just charge it 100% as often as you like!.
Balancing here can’t be overlooked of course.
