Well I got up this morning to the first real frost of the season and thought I'd won the jackpot with all the lights and warnings on the dashboard of my Mg 3 . Was lit up like a Christmas tree 🤣
This is usually caused by frost on the cameras, the lights should clear when you've defrosted. :)
Sounds like you didn't win the jackpot after all, just Jack Frost playing tricks on you ;) :ROFLMAO:
T1 Terry
Think had a couple of Jack Frost, moments this morning. Firstly the "P" for parking on the Dash, started changing to "EP" intermittently. Ignored it, went to Maccies for Breakfast. When I came back to the car, it was fine. Then got a tyre warning, right rear tyre low, so stopped to check, seemed ok to me, so again ignored it. Warning light went off, now back to normal. And been ok since. So not sure exactly what happened, frost/foible/glitch/quirk/characteristic?
Anyway all's well again. Still thinking of rejecting it though, piece of utter, Crap 🙄😉🙂👍
I live in Finland, and we’ve had freezing temperatures for five weeks straight without any issues (Today morning minus 19 celcius). Sure, the front camera is occasionally frozen and fuel consumption is higher than summer, 'cause the heating doesn’t run on EV mode alone.
Minus 19°C ..... it's colder there than in my deep freeze .... I'm not sure I could ever acclimatise to that sort of cold ...... even a diesel heater, rigged to run slow continuous, would need a heater in the diesel heater fuel tank to stop it from turning to wax ......
T1 Terry
T1 Terry
Today: -22,3 and I live southern Finland.
Up north we got something like -38 celsius 🥶😂
Have you thought about what you might have done in a past life to deserve such punishment?
My 2 yrs in Tassie, I doubt it ever got into -double figures C .... but possibly the wind chill factor did ..... I made point of not looking to see how cold the thermometer said ..... not that any of the work places had one on display :rolleyes: but I'm sure I would have felt even colder and packed up for the mainland if I'd seen -10*C or something .....
T1 Terry
T1 Terry
Actually, this cold weather is pretty nice, because when it’s freezing the sky is usually clear and the sun even shows up. Although, let’s be honest that -20°C is getting a bit ridiculous!! 😅 -10°C is muuch better!!
The real villain here is the darkness. In November sun shined total 50 minutes!!! Fifty. Minutes. Whole month!! 😬😬😬
But...at least we don’t have any poisonous spiders or snakes. Small victories! 😅
But the MG3 hybrid has been running beautifully despite the cold! And the iSmart app’s preheating has been a lifesaver too!
Ah yes, Australia, the only reason it isn't trying to kill you is it's still trying to figure out if it should attack or run :ROFLMAO: Even some of the cute and cuddly things you can pick up and play with while the sun is up, can turn real nasty as the sun goes down and certainly not something you want to meet in the dark.
A Sydney Funnel web spider will walk over you or around you, as long as you don't look threatening to it, put your head between your legs and kiss your butt goodbye if it sees you as a threat, like disturbing it when you climb into a sleeping bag or put a shoe on that it has decided seems like a safe place to spend a while .... none of the snakes appreciate being stepped on etc
T1 Terry
When it was minus 20 degrees Celsius, the hybrid system was completely confused.
Even the car’s climate control was set to low ( 18 degrees), the car wouldn’t run on electric power at all, and the battery stayed at 100% the whole time.
The car kept reporting that regenerative braking was disabled, and the engine revs repeatedly shot up high.
Now it’s only minus 10 degrees and the car works normally and there are no issues.
