Jump starting another vehicle with MG PHEV
Cheshire Fox
Warrington
MG HS PHEV
Hi all,
My daughter's car needs a jump start using leads following the cold weather. Can I do this safely using my MG PHEV, and if so, cab anyone provide instruction, please? Thanks in advance
Here you go
"Top Tip" - I would strongly consider purchasing a 12 volt battery booster pack, then you can carry it around in the car.
These are a much better and safer idea than trailing jumper leads across both cars TBH.
Good point!
Also, as it’s an independent form of power, therefore you run no risk of causing any paint damage to your own car or it’s battery, just trying to help somebody out.
Very worth while investment !.
Get one that is powerful enough to jump a larger type engine, then you will have plenty of power in reserve.
Oh …. and yes it can be still used to jump your PHEV and a BEV.
