kwartelknaap
- Dec 26, 2025
- Netherlands
- ZS EV
I put some LED in my ZS, and its so much better! Way more light and better matching color.
Ideally, the LED bulb should be mounted vertically in the headlamp. Some LED bulbs can be rotated for this reason, but the one I have cannot. Is it possible to rotate the socket instead? I do see a few screws (see photo) and markings that look like something has been adjusted. Does anyone know?
And finally, the headlight is aimed quite a lot toward the ground, much more than necessary (it was the same with the halogen bulb). I’d like to adjust it slightly upward. Is that done with the Allen screw in the red circle? Of course, I’ll check afterward that it doesn’t cause glare by aiming it at a wall and driving backwards.
