check with your dealer whether they can fix it under the warranty. if I find something useful for you, I'll post it hereYes both of them (left side photo attached with headlights on) . The indicators worked as normal though.
Thanks fred12345. My car is scheduled for its second service next month, and I'll bring up this issue with my dealer. I'm just surprised that it occurred on a low-mileage, two-year-old car, but hopefully, it's covered under warranty.check with your dealer whether they can fix it under the warranty. if I find something useful for you, I'll post it here
just to give you an idea what it could be -
CAUSE ... The connection between the LED module and light tube inside the headlight is damaged.
CORRECTION... Inspect and replace the affected LED module. Replace the headlight only if internal damage is found to the light tube.
based on your inspection:
Discoloration is present only on the LED module- Replace the affected LED module only, following ISTA/AIR repair instructions based on the vehicle model.
Discoloration is present on the LED module AND the light tube: Replace the complete headlight and the LED module, following ISTA/AIR repair instructions based on the vehicle model.
Just to make sure, check whether it's actually the indicator that is glowing faintly? I can't figure out from your photos... Good luck with warranty, should be OK. I would call them in advance of service so they know what to order...Thanks fred12345. My car is scheduled for its second service next month, and I'll bring up this issue with my dealer. I'm just surprised that it occurred on a low-mileage, two-year-old car, but hopefully, it's covered under warranty.
