decrep
- May 5, 2024
- Solutions
- 1
- Location
- Mandurah Western Australia
- MG4
I think, regen can cause disk corrosion. I thought charging to 100% would sort this, but regen starts kicking in around 95% so unless you do very short trips the brakes don't get much use. also "regen mode", doesn't actually affect regen very much, only the way the go pedal works. pressing the bake pedal will also activate regen.
Friction brakes are only activated under hard braking, when regen isn't enough. Or when in reverse, regen doesn't work in reverse.
So Rolfe, go backwards down a slope so you need to use friction brakes and see if there's any squealing, your pics didn't look like a lot of corrosion.
Definitely do this before taking to your mechanic, that will get rid of any minor corrosion and give him a better idea of what's going on.
