MG 5 EV V2L
evo 098
Warrington
Not an MG
I had a Mg zs new model but I changed it for a Mg5 brand new but the old model, I want to no if I can still use the vehicle to load cable adapter type 2 for camping and stuff,evo098
There is not v2l on the mg5 lr, I looked at the labels under the bonnet. There is a hefty dcdc charger for the 12v battery so you can fit a fairly hefty inverter yourself.
I have received my V2L cable from aliexpress last weekend for our MG5 facelift
I was able to run a 2KW heater in my garage (y)
You need to be careful to manage the total load that you take with that lead. It may allow the car to provide more current than the connector is rated for on a continuous basis. If the resistance between PP and Earth is the MG "standard" ~470 Ohms then the car will provide up to 32A whereas a 2.5mm² conductor is only recommended for 20A. The correct resistance should be around 1,500 Ohm.
