sammoj
- Jul 16, 2025
- Newcastle Upon Tyne
- MGS5
Hi All
Just out of interest tonight I decided to have a chat with Google Gemini AI about the MGS5. I thought this response about the NMC 64kWh battery was interesting and worth sharing.
J
The 64kWh NMC (Nickel Manganese Cobalt) battery in the MG S5 EV is part of MG’s third-generation battery technology, built on the Modular Scalable Platform (MSP). It incorporates several advanced safety systems specifically designed to manage the higher energy density and thermal characteristics of NMC chemistry.
Note for NMC Owners: To maintain these safety margins over the long term, it is recommended to keep the battery between 20% and 80% charge for daily use, as leaving NMC batteries at 100% for long periods in high heat can increase internal pressure and stress on the cells.
J
1. Zero Thermal Runaway Technology
The most critical safety feature of this battery is its Zero Thermal Runaway design. This system is engineered to prevent a "domino effect" if a single cell fails:- Passive Isolation: The pack uses high-performance thermal insulation between cells to block heat transfer.
- Rapid Heat Dissipation: If a cell enters an abnormal state, the system is designed to vent heat and gases quickly through a dedicated pressure-relief system, ensuring that open flames do not spread to adjacent cells or the cabin.
2. "One Pack" Protection & Ultra-Thin Design
The battery utilizes an innovative Horizontal Cell Design, making the pack only 110mm thick. This contributes to safety in two ways:- Low Center of Gravity: By sitting lower in the chassis (a 490mm center of gravity), the battery reduces the risk of vehicle rollover during high-speed maneuvers.
- Structural Integrity: The battery is encased in a reinforced high-strength steel frame that acts as a structural member of the car. In crash tests, this frame is designed to absorb side-impact energy, protecting the internal cells from deformation.
3. Advanced Thermal Management
Because NMC batteries are more sensitive to temperature than LFP alternatives, the S5 uses a more sophisticated active cooling system:- Liquid Cooling Loop: A dedicated cooling circuit maintains the battery within its optimal temperature window (typically 25°C to 35°C), reducing the risk of overheating during rapid DC charging at 139kW.
- Real-Time Monitoring: The Battery Management System (BMS) monitors the voltage and temperature of every cell group 24/7, even when the car is parked, and can trigger cooling if it detects an abnormal temperature rise.
4. Electrical & Crash Safety
- High-Voltage Disconnect: In the event of an airbag deployment or a significant impact, the car’s pyrotechnic fuses (pyrofuses) instantly "fire," physically severing the high-voltage connection between the battery and the rest of the vehicle to prevent electric shocks or post-crash fires.
- IP67/IP69K Rating: The battery housing is dust-tight and sealed against high-pressure water jets and submersion, ensuring electrical safety during flooding or deep-water wading.
5. Safety Ratings
These battery safety features contributed to the MG S5 EV achieving a 5-star Euro NCAP safety rating in 2025, with a 90% score for Adult Occupant Protection. The testing specifically verified that the battery remained stable and the cabin was protected after severe frontal and side-pole impacts.Note for NMC Owners: To maintain these safety margins over the long term, it is recommended to keep the battery between 20% and 80% charge for daily use, as leaving NMC batteries at 100% for long periods in high heat can increase internal pressure and stress on the cells.
