APMG
- Oct 14, 2024
- Location
- United Kingdom
- MG4 Trophy LR
I have been frankly a little addicted to setting up little modifications, upgrading software versions and tweaks which will help me in my day to day and are functional!
As this forum has been so great and many suggests via it. I have complied a list to help those new or existing owners add a little extra to their vehicles. Most of these are from AliExpress so if these links do go down let me know and I will try link a suitable counterpart!
Each item is broken down into its cost, how difficult it was to do/install, its functionality and delivery windows. As well as the links to save you a google search! Comments are under spoilers for easy scrolling and to only read what is appropriate to you.
Hydraulic Frunk Upgrade (In black)
Cost: Reasonable (£20 at time of purchase)
Difficulty: Easy/Medium
Function: 10/10
Delivery time: 7 days
Link: https://www.aliexpress.com/item/1005005124400689.html
Mudguards
Cost: Cheap
Difficulty: Medium
Function: 10/10
Link: https://www.aliexpress.com/item/1005006077864051.html
Sill Protector Stickers
Cost: Very Cheap
Difficulty: Medium/Fiddly
Function: 8/10
Link: https://www.aliexpress.com/item/1005007499177247.html
Key Fob Case
Cost: Cheap
Difficulty: Easy
Function: 10/10
Link: https://www.aliexpress.com/item/1005006901275675.html
Rubber Door Inserts
Cost: Reasonable
Difficulty: Easy
Function: 9/10
Link: https://www.aliexpress.com/item/1005005209599093.html
Central Armrest Storage Box
Cost: Reasonable
Difficulty: Easy
Function: 10/10
Link: https://www.aliexpress.com/item/1005007219318190.html
Internal light upgrade
Cost: Reasonable
Function: 10/10
Delivery time: 1 day
Link: https://www.amazon.co.uk/dp/B071LNH2D3
CarMats Superior Floor Mats+ Boot Mat
Cost: Expensive
Function: 10/10
Delivery time: 6 days for boot, 10 days for custom car mats.
Links:
Seats: https://carmats.co.uk/products/mg-motors-uk-mg4-ev-2022-car-mat
Boot: https://carmats.co.uk/products/mg-motors-uk-mg4-trophy-ev-2022-boot-mat
Windshield sun shade
Cost: Reasonable
Function: Awaiting summer!
Delivery time:7 days
Links: https://www.aliexpress.com/item/1005007423724463.html
Feel free to add any recommendations to this thread. I will try keep the OP up to date as I add or change things.
I did look at the MG4 Badge/Fangs, but decided against them for now. I have a 3d Printer and I also printed the phone tray guard but not yet put it through its paces. It would be nice (or perhaps I will need to do is) is 3D Scan some parts such as the badge and make my own, cheaper version with PETG/ABS.
Pending delivery and review (so I remember!)
Function: 10/10
Fairly simple to install, took me probably 5-10 minutes most of which was making sure I was doing it right, you'll need a little pry tool and some strength to remove the gap fillers of which these replace.
Install references:
Install references:
Mudguards
Cost: Cheap
Difficulty: Medium
Function: 10/10
Installed yesterday on a dry day. Took me a few minutes to figure out which one was which (they only fit one way) then started with drivers side wheel. I turned wheels away so get some more space to work with. You will need to be down on the floor to get to the screws, typically 3 and with one on the underside. I would recommend a rachet socket with a philips to get in there and tighten up.
Took me about 10 minutes for the whole car, they seem to stop a lot of the splash back in these winter days where there is a lot of water on the road. Quality is ok and they match the black plastic trims.
I spoke with my insurance about these, they couldn't find anything on system which requires notice which is great, your mileage may vary so worth checking!
Cost: Very Cheap
Function: 8/10
These are a little tricker, I wanted the MG logo ones but the seller supposedly didn't send the ones I asked for so minus some points for that. They work fairly well and are a bit tricky to install and get in parallel. I would make sure you clean up the space you're sticking too first, then slowly work along the top edge so its as flush as possible. I did get a boot one too but this sticks out a little bit so may replace.
They are decent quality and should hold up and protect your paint in your door gaps.
Key Fob Case
Cost: Cheap
Difficulty: Easy
Function: 10/10
Easy to install just squeeze in a go. Decent quality and hopefully protect the stickers on the original keys.
Rubber Door Inserts
Cost: Reasonable
Difficulty: Easy
Function: 9/10
Easy to install. I some how got an extra one and I am not sure if this allows the Qi charging but for the front and back doors, as well as the gaps it works nicely.
Cost: Reasonable
Difficulty: Easy
Function: 10/10
This should be stock. Seems like the factory missed a beat and it adds a perfect little area under the armrest for storage.
Cost: Reasonable
Function: 10/10
These are so much brighter and better than the originals. The MG4 is dingy without upgrading. One issue to point out these lights are "thicker" than the initial inserts, I ended up removing the SoS/Light area to plug back in the light socket as it pushed into the plastic when fitting. This is done by two screws in the sunglasses holder then you slowly pry the two sides and pull towards the windshield and it pops out. I fitted both in this way and pre-watched this chaps guide;
Cost: Expensive
Function: 10/10
Links:
I went with the Superior in black with Carpet Heel pad. The originals I had seemed to poorly fit as well as missing drivers side "locking" mechanism. The new mats are very good quality and make the car look a lot better. Boot mat is great too and allows me to put things in there without worrying about scuffing up the fabrics.
I would recommend investing in some good quality mats if not already. Specially when winter is fully here.
Cost: Reasonable
A bit fiddly and unsure of its practice user yet until summer rolls around. Seems decent enough quality and storing in the back passenger pocket.
Internal Rear Lights
Cost: Reasonable
Difficulty:
Function:
Delivery time:
Links: 2PCS Bread Light Trunk LED Foot Light Magnetic Touch Light Car LED Interior Light Car Roof Lighting - AliExpress 34
Seat Gap Filler
Cost: Cheap
Difficulty:
Function:
Delivery time:
Links: 1 Pair Universal Car Seat Gap Plug Strip Side Seam Car Gap Filler Leak Proof Seat Gap Storage Organizer Interior Decoration - AliExpress
Cost: Reasonable
Difficulty:
Function:
Delivery time:
Seat Gap Filler
Cost: Cheap
Difficulty:
Function:
Delivery time:
