jamherber
- Mar 6, 2024
- Bridport UK
- MG4
We tried to reject ours due to this vibration issue after 2 days with the new car but the rejection was ‘rejected’ as MG Uk are stating this is a characteristic of the model and does not effect safety, so I suspect you’ll hit the same brick wall.Just got back from my local MG dealer with my vibrating Xpower. I took there to see if they could do anything about the vibration/throbbing between 58 and 72 MPH that it has had from new. It’s now done about 800 miles. Unsurprisingly there is no simple fix.
Their inspection report was as follows:
“Inspected the vehicle and also another same vehicle and both vehicles have the same vibrations and distortional noise. Suspect it is characteristic of the vehicle”
I noticed they also had one more Xpower in the service area.
They did not know how to fix the problem and said I should contact MG for a solution. I got the impression they were not getting much help from MG UK.
Interestingly they tried rebalancing the front wheels and on the drive home it was a lot worse. This seems to point to a balance issue in wheel/drive train somewhere. If the problem was anywhere other than my usual cruising speed I could live with it, but at 60-70 MPH it’s very irritating.
I have had the car for 28 days so when does the 30 day rejection time run out ? Or does the fact that I have reported it to a dealer stop that clock ?
Only option at that point is to get an independent engineers report and head down the legal route. We decided not to risk this and have now accepted the car back but apparently there are some new suspension components being released soon to try n address this and we are on the list to have these retrofitted when they are available.
Sorry it’s not better news.
