MG4 X Power Vibe/Hum 65 to 75mph
That’s exactly why it’s not a drive shaft issue ..
Im by far a car designer or master mechanic engineer..
For them to replace sub frame bushes etc etc it has to do with transferring vibration..
Vibrations can travel from the strangest places to the strangest place ..
As for other vibrations after my car has been fixed well nothing that I would say I payed 55k aud for a cheap arse rocket on 4 wheels. That I don’t really expect.
Apart from the major blown high voltage module 6 weeks ago and the vibration that is now fixed the car for the mist part has done good ..
Little story back on 1995 I was a apprentice mechanic guy bought his brand new Camry in complaining of wind noise Forman bent the door frame a little help a bit nothing spectacular
The guy kept coming back complaining of a wind noise in the end the Forman said look go buy a merc or bmw this is a cheap car so expect these sort of issues ..
Problems like the vibration is an obvious fault and should be fixed no question but little other things revolves around the price you paid
The issue is that there is at least one member where that fix hasn't cured the issue
But at least in France and other countries MG acknowledge the issue, and are trying to fix it with the Stage 2 fix (now allegedly deleted from MG UK database if it was ever there).👍
I think it was here, I seem to recall a member posted some paperwork relating to it, a good while ago, I'm sure it came from FB.
The garage was going to do it and then were told by MG UK it didn't work and stopped them doing it.
Was a good while ago but I'm pretty sure
Yep, I'm sure you're right ... @case dismissed was one of them.
Seems he's still having trouble getting paid his compensation from Oodle Finance.
Updated videos here on his Ombudsman rejection hand back and Oodle Finance not playing ball (beware both are long watches @siteguru 😉😁)
Seems MG UK staff deny the issue exists now.
Did we decipher yet if it is year specific or county/mfg.plant specific.
Although if it was also in France that precludes RHD specific.
Was also in China, a member from there mentioned it first, no one knows if they have cured it or merely masked it in later cars.
Hence the numerous debates over the monrhs about the potential for premature wear on parts
What a shame. MG don't seem to have a bloody clue. A perfectly decent motor. Spoiled by a half arsed company.
Doesn't seem to be affecting them though, if the sales are anything to go by.
And that's probably all they are bothered about. 🙄🤪
Seems like when MG/Rover were in British ownership too!
And I can say that as an owner of a 'Project Drive' era MG.
While my XPOWER does have the vibration, it seems now to be only under certain circumstances - which is weird as it literally did it on the way home from the dealer quite badly, but it's done it less and less the more it's been driven. It's approaching 20,000 miles now. Only thing other than miles on the car that's changed is it's had a set of new tyres, Hankooks instead of Bridgestones. I have to also say that Bridgestone are one of the brands I tend to avoid if I can along with Pirelli as I've never gotten on well with any of their products so much.
Probably going to take mine and get the wheels balanced as a check, i do feel a vibe / drumming in the chassis when at the said speeds sometimes, today in the speed range i was getting buzz/ slight wobble in steering wheel.
Got to go into dealer next month for software issue so will mention it there too.
Either:
"Never heard about that"
or
"They all do that Sir"
Indeed, local dealer is pretty good just want to bring it to their attention/ noted with MG ( in case ever a solution😂) and get their input.
Also need to recheck tyre pressures, running just over 40psi but not checked in a good while and colder now may have dropped.
It is leased but if i buy it first job will be swap stock tyres.
Hendy MG Poole changed all 4 of our tyres for some much better Michelins free of charge when we complained about the vibration issues but in 2024. Only had the stock tyres on for 200 miles but that was plenty - you don't realise how bad they are until you change!
The tyres did improve the vibration a bit too.
Hendy MG Poole is where i go👍.
Push for replacement tyres. Their master MG tech is Mark Franks who is a top guy (he is unofficially disgusted with how MG UK have treated their x-power customers with the vibration issue).
I suspect MG UK will now no longer be funding this though, since rolling out their 'acceptable characteristic' claptrap, but nothing to lose - although not a fix, you may end up with much better rubber!
Thanks, i will have a go.
I haven't taken the plunge yet waiting for a mate to pay back a loan. :unsure: :LOL:
Just wondering if the noise is simply the tires. Most noise from vehicles comes from the tires.
My current pickup is so loud that when I come off the expressway into town I wonder who has turned up the music volume , when it is simply the background noise that has diminished.:rolleyes:
Tire noise, wind noise, engine rumble, transmission whine, et al..
Electric/modern cars are so quiet that any noise seems amplified.
OK steering shimmy is another thing.
