Mg5 long range roof bars and box
Ian MG5
BARNSLEY
Hi all
Just a few photos of my mg5 with menabo brio roof bars (£38 eBay)
and Halfords 420l roof box (£240)
Test fitted them today they fit well together and seem very sturdy
Cheers for looking
Ian
Hi all
Cheers for looking
Ian
Looks very good - only comment is positioning of bars. Shame the manual doesn't say anything too specific like the Ford one did, but does say this:
Pay attention to the following when using the roof luggage rack:
  • Fix loads towards the front of the roof as far as possible,
    and distribute the roof load evenly.
I took this as putting the front bar as close to the rail/trim join as I dared ?‍♂️
Hi Biffo
I also read the none helpful paragraph in the hand book ?
Thanks for info
It was just a quick try to see if everything fitted together ok
(Just need a ladder now so I can reach the roof box haha?)
Cheers for reply
Ian???????
This is likely to try to stop the rear axle from being overloaded and having a negative effect on the steering (pendulum effect).
The front axle carries most weight when there are two front seat passengers and nothing in the back/boot. Once you start adding rear passengers and cargo it is possible to take weight off the front axle, due to the weight being added behind the centre line.
It's amazing how moving a load a few inches has a massive impact on lorries axles, even when they are close together.
I believe they are suggesting that by keeping the weight forward you help to exert some of that weight on the front axle to 1) distribute it more evenly and 2) help keep the correct downward pressure on the front tyres.
Unless you're running at max weight however it should be fine ?
Ha - reminds me of many years ago coming back from a booze cruise in an Escort with 4 adults and a bootful of beer. The front wheels were hardly touching the ground, it was quite scary at times!!
I really wish the manual was a bit more detailed - this is from my old Grand CMax manual, zero room for interpretation
I achieved 3.0 miles per kWh on a long motorway drive, I think I am getting up to 3.5 without the loaded car and roofbox. So, a reduction of 25 to 30 miles overall (171 miles down from 199.5 miles if using all of the available 57 kWh).
The GOM is useless when there is a roof box on top - it doesn’t give accurate guesstimates. I think approx 70% of GOM range is a safe bet for a normal roof box. However there’s the Calix Aeroloader box designed for EVs which is more efficient at minimising drag.
Has anyone experimented with different roof box positions and effects on miles/kWh?
I read some scientific paper suggesting further back on a square backed car was better, though unconvinced how closely this applies to the ‘5.
Just got myself from ebay £29 new bars including delivery, and a £42 2nd hand 320L box. I currently have it offset towards the driver's side for easier access, as far back as I could without drilling new holes in the box.
