Mg5 vibrating through cabin when accelerating from 50mph
Jones886
Birmingham
Hi all posted on here a while back that I was having issues and still unfortunately unable to pin point the issue
When I get the car up to 50mph and stick my toe down the whole cabin vibrates (sounds daft but if my leg is up against the centre console you can see My whole leg wobble like jelly joys of getting fat haha then after 60mph it disappears (have tried full power and 40/60% still does it.
What has been done so far
2 x road tests with mg upon second road test he could feel it also (awaiting MG technical)
2 x new rear tyres replaced today as was starting to go slightly out of shape and uneven tread wear 47000 miles tracking also checked and all ok
Major service today including transmission oil change
Car has been in and checked for ball joints etc said all ok
All new alloys under mg warranty due to peeling.
I'm just really lost now what to do all I can think off is a wheel bearing is on the way out or there is a issue with my diff. Issue is like mg said it's like finding a needle in a hay stack.
Any advice would be great ?
Are the front wheels balanced ?
Hi yes all been done just completely lost as to what it could be now; wheels were balanced when I had the new wheels replaced under warranty.
Just an update on this so I've taken it to a different garage and they have done a road test and identified there is an issue. They have re balanced the wheels and still vibrating so it's the car off the road and currently with mg technical . I'm just actually glad the fault has been found and I'm not getting fobbed off. I suspect play in the differential mount as that can cause it but I could be wrong
Dan
