Coady
What voltage reading should I expect after a full charge for MG 5?
Mine shows highest 4.1, down to 3.7/3.8.
Sorry if I'm a bit thick! I'm looking at the left side of the right hand dial. Usually showing 4.1 V ??Sounds more like Miles/kWh to me.
Think I've found it. Page 10 of manual.Sorry if I'm a bit thick! I'm looking at the left side of the right hand dial. Usually showing 4.1 V ??
Mine usually shows 14.1VSorry if I'm a bit thick! I'm looking at the left side of the right hand dial. Usually showing 4.1 V ??
Is that voltage or miles per kW?What voltage reading should I expect after a full charge for MG 5?
I can't remember exactly but I've definitely seen 13.8V on my displayMine usually shows 14.1V
12V battery is on the RHS and the other side is % HV. You can see the HV voltage on the electric settings changed by the steering wheel buttons. That 12V battery usually shows around 14V when in ready mode. And the HV on full charge is 405V on mine.Yes the 12v battery. Which is what I believe the OP was asking about. At least that is how I am interpreting. it. I thought the HV info was on the left side?
