deanWombourne
Bit unusual this, normally when they break they won't turn on!
The car is sitting on the drive right now, and here's what it's doing:
Start/stop button won't turn off (light on button stays green, headlights stay on etc).
Keys won't lock the car, just honk the horn when we try (probably because it's still turned on!)
Pushing the start/stop button will turn air-con on/off, so it's definitely working as a button.
Battery voltage displayed on the dash is 13(ish)V so it looks like the 12v system is good? (Main battery is at 80% so that's fine too)
If i put the car into reverse the rear camera starts up, but pressing accelerator does nothing
While pushing the start/stop button turns air-con on/off, the dial on the display showing power (and regen) remains off (i.e. pointing down at the max regen position - I'd expect it to go to the 0 position when the car is ready to drive).
I've tried both sets of keys, tried the key in the recovery position (in the cup holder), and tried resetting the info system (bit of a long shot) with no change.
Any suggestions before I accpet failure and call a garage over Christmas?
