MG5LR ( May22) / Zappy charger
RogerWill
Fareham
MG5
Generally I home charge and ALWAYS have to check on the dash that there is a charge time showing.
Occasionally for various undetermined reasons this does not always happen.
Yesterday evening on eco 1.2A the charge stopped.
It took about 15 attempts to get a charge going as it would charge at 7.2A even on the eco setting, or boots would show on the Zappy.
This morning upon start up all was ok in D/ drive , no forward motion.
Note auxillary battery was showing 12V.
Turned all off , then on, all ok and auxiliary showing 13.8V.
Am aware of others issues with battery- has anyone had any of the above.
Thank you
PS nice now to see >4m/kW / 260+ range is it not
These comments suggest that on the first 'turn on' the brake pedal had not been pressed either at all or sufficiently long. 12v battery at 12v indicates HV battery not engaged, no drive indicates this too.
Second time, obviously all OK, 12v at 13.8v indicates this, i.e. HV battery charging 12v etc....
