nicho12
- Dec 1, 2024
- Location
- colchester essex.
- ZS Hybrid+
Every time i get in my car it keeps asking to re install my mobile phone any ideas welcome.
I suggest you try using another USB cable for the connection. Sometimes the issue can be related to the cable, as some cables may not work properly for data transfer or charging.Hi Nicho.
I had something similar, mine is due to the car not connecting to my iPhone. It keeps displaying “ Please connect the mobile phone to the USB port of the vehicle and check the mobile phone settings”
Of course the iPhone is already connected and is charging. Anyway we play the merry dance of disconnect/reconnect until the car submits and the map appears on the screen.
I’ve just tried a new approach, connect the phone first, and then start the switch on process. This appears to have overcome the problem, keeping my fingers crossed.
Cheers Noel
Hi Noel My problem is i have an old mobile which i connect with bluetooth it connects ok but every time i go out to drive it keeps asking to connect just by pressing yes on my mobile sorry my mobile is as old as me.I suggest you try using another USB wire for the connection. Sometimes the issue can be related to the wire, as some wires may not work properly for data transfer or charging.
I took your advice and bought a new USB A to USB C cable. USB C is not straightforward, there are many versions. The most important is that it includes DATA, i.e not just charging.I suggest you try using another USB cable for the connection. Sometimes the issue can be related to the cable, as some cables may not work properly for data transfer or charging.
