No heating
iainfm
Dumbarton
MG5
Hi, hope everyone had a great Christmas!
Drove across the country to visit relations today. 100% charge before I set off, but no heating on any setting at all. Which was a bit chilly as it's only 3degC outside!
Got here safe, and hoping it'll miraculously sort itself before the return trip.
Any other suggestions other than crossed fingers?
Hi, I've noticed the heating is a bit rubbish, bordering on non-existent when in Eco mode but in normal I've not had a problem.
Which mode were you in?
Hopefully just a glitch, otherwise it's a trip to the dealer (
I had a weird one on Friday, for the first trip (1.5 hours) I had no Kers3, it just wouldn't allow me to set it. Next run it was just working again.
Did you charge to 100%? If so that combined with cold battery could contribute to the non Kerr’s feeling.
I was in eco, which has definitely given me heating before. I did try normal as well though.
Home safe, if a bit chilly. Had a play with the heating while watching the ammeter display (while parked) and it doesn't flinch when changing the temperature at all.
The other weird thing that happened was I saw the rear de-mist LED flashing very briefly for a while when it was turned off, but no idea if it's related.
So, a call to the dealer as soon as they open I guess. Hopefully it'll be something simple like a loose connector or something.
At least it didn't happen when the screen was frozen up completely!
Hopefully it'll be an easy fix and fairly simple.
In an ICE a cold blower (when it should be hot) would either be a simple valve to feed the matrix failed, cable/electronic control, a panic as the engine overheats because you've lost all your coolant or a knackered water pump, radiator, etc. etc. ?
Good thing about electric cars in theory if one part fails (that isn't the motor) you can carry on regardless - ice permitting in this case!
I had a very prompt response from the dealer, who said its a PTC (positive temperature coefficient, according to Google!l heater in these.
My understanding is they're (usually/often/sometimes) a ceramic heating element, so possibilities are/include a failed element, blown fuse, bad relay (or solid-state equivalent) or a bad connection...or something else.
I'll check the fuses later (I'm assuming it'll be one of the ones under the bonnet rather than the ones behind the dash*) but if not then it's a dealer job, and they're not open until the 5th.
I'm planning any major excursions, but it is a hassle - they're an hour away and I've just started a new job. Such is life though!
*Edit: According to the manual, it looks like F47 (5A) inside the cabin is the one to check
Fuse 47 is intact, so looks like it's getting a trip to the dealer in the new year!
Sorry about this, Going of on a tangent, does anyone get a smell of burning when first switching the heater/ demister on ????
My 5 has been in the dealer for nearly 4 weeks now, same problem, parts on back order eta late January
Jeezo. Has the dealer been helpful, eg given you a courtesy car while they have yours? Never had to deal with a new car warranty issue before, so unsure what to expect/demand!
While the weather's mild enough it's fine (it's certainly boosted my miles/kWh rating), but if it was to get colder there's no way I'd be able to keep the screen ice-free.
Running an mg3 courtesy car just now which barely manages 45 mpg, I live in the north of Scotland so demisting defrosting issues meant the car was unusable, part supply is a major issue just now, my dealer has four franchises and suffering problems with them all, they currently have in excess of 100 courtesy car/ demos out on loan, if your dealer cannot supply a car push them to authorise a hire car from MG
Thanks for that. I used to not live a million miles from you (Kirkhill near Beauly/Kiltarlity) :)
Which dealer is yours at? Might be worth mentioning to mine to save a bit of their time diagnosing the problem.
Dicksons Inverness, I have seen others with the same problem on forums on Facebook,
Parts ordered are a heater element and an electric valve, other than that I don’t know what exactly is wrong
Ah, that's maybe why I cannot get a loaner. My car is in there for it's first service next week.
Bodger - yes, I get an electrical burning smell, for maybe a minute or so. It only started doing it in the last couple of days (car is about 4 weeks old). I'll start a new thread about it.
