Noise rear + Mirrors on rear wheels
Robertoba345
Spain
Cyberster
Good morning, I bought my Cyberster yesterday, and with the hood closed, I hear a noise as if something's loose in the back. It's not from the trunk; I've already checked. I can't hear anything with the hood open. Is this happening to you?
I also wanted to add, is it possible for the mirrors to go down when you put R?
To the forum. Enjoy your new motor. 🙂👍
The mirrors have a manual switch on the drivers door to put them in, I press mine and use the cameras if I’m going into a tight space.
Could the rear noise be a stone?
I mean the mirrors fold down to see the rear wheels when parking.
I don't know if it's a stone, but it's under the plastic where the hood rests.
In this photo of the Chinese software we can see how the side cameras can be directed at the rear wheels, why in Europe don't we have these 3 cameras automatically when activating R?
Is anyone working on how to install Chinese software in Europe? :unsure:
Hi, I got my GT May 19th. The car is fantastic but I also hear a strange noise coming from the back when the roof is closed. No issues when driving top down. I need to have it checked by the garage @ 1500KM (standard procedure MG Belgium) so I'll ask them to have a look at the noise issue.
It was solved for me, it was a problem with the trunk, the rubber bands that stop the door were not stretched enough
This identical problem has happened to me. Have you asked MG to look into it? To discuss further suggest you Private Message me.
Hi, does anyone know how to remove the plastic panels next to the seats? I'd like to cover them with Alcantara, but I don't want to break them when removing them.
Thanks.
Plastic trim removal tools are best but a carefully used narrow paint scraper works. The chances are you will break the plastic clips that hold the trim items but these can be replaced easily, just make sure you obtain the correct size clips.
@Robertoba345 can you post a picture of the rubber bands, to show exactly where they fixed it?
I have the same here, something makes noise when roof is closed, in the rear and on right side of the car.
These two have to be adjusted so that they hit the plastic below when closing.
