Okay, so as you have the NMC battery, what is your usual charging level set at ?.
Have you tried resetting both of your trips yet ?.
So, you are a relatively a low / average milage user then.
Historical driving data is stored by the car and is used to predict the range ( after you have charged ) on the GOM.
IF you have not reset your trips for a while, this can influence the predicted figures show, as your range after charging.
Resetting the trips prior to charging should offer a figure that is closer to the ball park figure of the estimated WLTP range of the car.
Remember, the cold weather WILL have a big negative affect on that predicted range though.
To offer you a some type of comparison, we also have a Trophy LR that is about 18 months old and has covered, roughly about 15,000 miles.
Long story short, I have been monitoring my predicted range on car from it's collection date in March 2022.
It has been exclusively charged from our home A/C wall box and has not been subjected to D/C rapid charging.
My charging schedule level, has mainly been set to a 80% SOC and with both trips zero'd before charging.
Charging to above 80% has only happened on a handful of occasions.
I have chosen to adopt this because one it suits our needs perfectly and two it offers a means of consistently plotting the cars charging behaviour set against the predicted range it offers.
So, it has returned a predicted range of between 211 - 212 miles consistently, over that time scale.
However, as the ambient temp has dropped recently to as low as -5 degrees here, the predicted range has reduced it it's estimated value.
Why, simply because the HV battery pack is extremely cold.
Our car sit's on the drive 24 / 7 and is exposed to all of the weather elements, either good or bad.
When I completed a charge to 80% a few days ago ( both trips reset ) it predicted a reduced range of 206 miles.
Therefore, this clearly displays the negative effect that low ambient temperatures has on the HV pack.
"This is nothing to see here folks" and should be expected in bad winter conditions.
ICE cars are affected in a similar fashion, but as they are dragging around a huge back up of fuel / energy reserves in their tanks, nobody is that interested TBH.
