MonsterMonster
Has anyone had the same problem as me in that my Ohme Home Pro only gets to 3.8kW charging without the house drawing any other power?
Usually I've had to unlock the car, unplug, lock, unlock plug in, lock and then it would get to 7kW.
When I got the charger I inadvertently turned on load balancing and this gave the same result of low charging. I turned load balancing off and it worked at 7kW.
Its almost as if load balancing is back on again. I can't remember how to check this but I'll have a look on the threads here somewhere.
