• Guest, wishing you a happy New Year from the MGEVs.com team.
    We hope you have a peaceful and prosperous 2026.
P1B07 and P1E25
kevynnn
Poland
Hi,
Hi, I bought an MG after an accident last week, and I'm having trouble with two errors: P1B07 and P1E25.
Does anyone have an idea what these errors mean or how to fix them?
Hi,
The P1E25 fault code typically indicates a statically defective camshaft position sensor. This code is commonly found in Land Rover Freelander vehicles and is related to the engine's power train control module.
The P1B07 fault code typically indicates a "Battery Block 8 Capacity Decline". This means the battery management system (BMS) has detected that the capacity of a specific battery block (Block 8) is significantly reduced compared to the other blocks. It could also be related to a cell voltage over-voltage issue in Module 7.
Never had any myself so cannot say from experience.
Simple Google search though came up with the above, don't know if of any help or has any relevance to what sort of accident the car had? Neither are 'specific to car' codes, but it may help??
