hi i have the same problem but dont have a 2nd key ..i gave the car to workshop to fix the door. they removed the door lock plug and tried to open the ingniton .the car won't reconize the key even if you put it in to the back cup holder. it's gone into theft mode. how can i fix it, anyone? thanks
We had the wiring loom replaced under a recall from MG on our first ZS EV.
The technician left the key fob close to the car while the work was being carried out.
The car then thought a theft was taking place and set off the alarm and wiped out the code from the key fob.
Every time they connected the 12 volt battery the alarm would sound !.
The car would not boot up and was completely unresponsive.
They called and asked for the spare key.
This worked perfectly, but they needed to recode the first key.
They told me that they have to recode both fob keys.
The technician said that the MG process makes no mention of having the key, well away from the car when breaking into the wiring loom.
Although it was clear that it was this that had caused the problem !.
As the spare key was at our home address at the time the work was carried out, it was able to be recognised by the car and it functioned correctly.
