Professional undersealing company with EV experience
Use Lanoguard, highly recommend it, I saw the same concerns with the nut, bolts and metal underneath, bodywork should be OK, as 7 yr warranteed but do the rest, warm it first so spray easily, it dries over a couple of days, yearly job for a while
But Lanoguard only lasts 9-18 months, you have to apply it every year, too much faffing about for me.
Hi and thanks again for all your suggestions and comments.
As I am a pensioner without access to a lift, my days of doing engine changes etc are well and truly over (and not just because I have an EV) and doing something undersealing on my drive once a year or 18 months is now well beyond me.
I need a professional outfit to do the work and the Waxoyl treatment comes with a 3 year warranty and they ask you to bring the car back for inspection before the warranty expires. While it will inevitably cost me more, I think that is the way I will have to go although I am still to finalise the company and treatment.
Thanks again
Thanks again
Same here, I can get down and under the car easily, but I can't get back up. ?
I have the same problem and it's pointless for both of us to be stuck so you might as well do mine while you are down there :ROFLMAO:
A quick update as after a break to recover from an eye operation, I have now had my MG4 Trophy Waxoyled via a company called Automotive Protective Solutions (www.waxoyltreatment.co.uk) which works with number of specialists across the UK.
While this is not the most onerous of jobs, it has to be done correctly including electric-vehicle related considerations and requires a vehicle lift. The work was carried out close to home in Egham, Surrey, by Mike Wallis who does this type of work every day. He did not see any visible rust – even at the sills’ spot welds – which is encouraging. When you look at the pics you will think the result looks awful and would have been better in black (as you can see where you have already sprayed) however, I had specified ‘clear’ Waxoyl as I wanted the original paintwork, and any subsequent rust, to remain visible(ish).
As you will see, Mike removed the wheel-arch liners and dropped the front and rear undertrays to access and treat the areas most likely to rust. The generous treatment on the sills was done deliberately as they, and the front subframe, have been highlighted as having started rusting or being most likely to do so.
I had it undersealed as many are predicting that modern electric vehicle batteries will last the life of the car and that rust, crashes etc are increasingly likely to be the killer problem. The technology in the battery is supposed to be good for 1,000 cycles and with 6,625 miles on the clock, I have charged the equivalent of 31 cycles so at that rate the battery could last for more than 200,000 miles.
Now it is a case of ‘time will tell’.
Was this done at Marinello's near Screwfix?
If you introduce a non standard treatment to the underside you may well give MG the opportunity to void the corrosion warranty.
Did you check with them first and got everything in writing.
In the same vane, the bodywork has 7 year warranty, when you want to polish or ceramic coat it, to protect it, do you as MG before doing so? surely, extra oily protection has got to be better than the bare nuts & bolts underneath, and steel parts not being protected, jus' sayin'.
I'm not about to argue whether what you've done is an improvement or not. I'm asking if you checked with MG first as it might give them the ammunition to void your warranty.
So did you?
So did you?
this question come up on Facebook more than a year ago, with concerns of rust underneath on a few month old car, only surface admitted, but he put Lanoguard on it, I did same, mine went in for first service in March, and MG there did not mention it, no I did not ask permission, and protecting it only helps with its lifespan, hence warranty will hopefully not be claimed on, up to you how you think about it. your choice.
Thanks for all you comments/questions.
From the top:
No, not at Marinello's
Yes, I checked with the dealer and have it in an email and that's the reason I opted for the clear Waxoyl rather than the black.
If the battery lasts 1,000 cycles then corrosion could easily be the killer. Other issues, well who knows. Somebody could pull out of a side road and write it off - its the luck of the draw.
I hope that helps.
I doubt corrosion would be an issue before the battery and other issues happen first would it?
Rust has already been spotted on cars on the joins on the sills, just surface to be fair but on cars only a couple of months ol.
I'm sure @Macadoodle spotted some on his and a small chip on his roof showed signs of surface rust quite quickly, if I remember right
Yes any car that has paint chipped it’s important to act quickly to prevent rust under the paint
Would 7 year guarantee cover rust ?
    Votes: 1,096 77.7%
    Votes: 212 15.0%
    Votes: 103 7.3%
