Weeble
OK, to some of you wise old owls this post may appear as a little 'basic', and bits and pieces have been discussed recently elsewhere so I may be in threat of duplication, but can we please develop some sort some sort of a Public Charging Routine for newbies specific to the S5 and pin it somewhere -- the handbook is next to useless.
I've had my S5 for almost 6 months now and have never needed to use public charging. However, over the coming days I'll be going farther afield and will need to use a public charger for the first time, so I thought I'd have a 'play around' tonight to see what does what.
I have no problem with how to use the public charger itself so I put my home charger in 'Boost' mode to manually turn it on, as a substitute for the public supply.
TEST 1
1. Plugged in
2. Locked car
Nothing happened
TEST 2
1. Turned off scheduled charging in car and App
2. Plugged in
3. Locked car
Charge started
TEST 3
1. With car charging
2. Unlocked car to sit inside
3. Charging stopped
4. Sit in car (don't press brake)
5. Turn car OFF from pull-down menu
Charging resumes
TEST 4
1. Press the Stop Charging button on the App
Charging stops.
Questions:
Is this a recommended 'standard' procedure to follow or have I missed something (i.e. are there any other setting that need to be checked)?
There appears to be alternative ways of turning off the charge, so which one is recommended?
The help info on the car charging screen says that the purpose of the charge % setting allows the charger to keep going after a scheduled charge session ends, until the battery reaches the set %. In practice I've always found that the charger reaches the set % before the schedule ends and stops at that point.
The Set % field disappears when the scheduled charge is turned off on the car screen, but stays visible on the App screen. So does the % limit still take effect in a non scheduled charge session or does the car keep charging to 100% unless interrupted?
Hopefully not too daft a question.
Merry Christmas to all......
TEST 1
1. Plugged in
2. Locked car
Nothing happened
TEST 2
2. Plugged in
3. Locked car
Charge started
TEST 3
3. Charging stopped
Charging resumes
TEST 4
Charging stops.
Questions:
