Beng30
East Riding of Yorkshire
HS PHEV
Does/has anyone successfully used public charging stations?
I tried two today, a Mer one and a Pod, and at both was unable to actually get the car to charge.
At the Mer one the car kept aborting the charge with the control unit saying it was ready but an error occurred so to try reconnecting the cable. The Mer app showed the unit as charging but ISmart app showed not charging and every time I tried to start it charge it said failed.
At the Pod it was at a tescos and I used the Zapmap app, again Zapmap said it was charging but the ISmart showed not.
No scheduled charging was set, I’ve been using granny charger at home ok, I tried multiple times unplugging the cable, unlocking/relocking but nothing i did seemed to allow the car to want to charge.
Am I missing something? Is there a special method to get the car to talk to these chargers so it will charge?
75 plate HS PHEV Trophy
Are you trying to sit in the car while it is charging? My car will not charge unless it is locked.
No was being sneaky and taking advantage of not having to pay for parking while charging and there being actual spaces available in the electric bays unlike main car park 🤣 tried starting while locked and unlocked to no avail
Occasionally I have had issues getting a charge to start but after a couple of disconnects and reconnects I've got charging to work at several Tesco podpoints (Manchester, Salford, Nottingham) Fuuse (Lancaster) and ConnectedKerb (Cambridge). The worst one was a Wattif charger late at night in Cambridge which locked up and wouldn't release the cable! I Think their support desk was in Denmark so emails and phone calls went on till the small hours of the morning until they rebooted the charger and I could remove my cable.
I always use the CPO's app instead of Zapmap to avoid any third party interference (often a bit cheaper too).
I know you have said you haven't got any scheduled charging set, but double check both the car's infotainment screen and the MG app, just in case.
My rough guide is anything over 45-50p per kWh is more expensive than petrol.
Hope you get the issue sorted soon.
I have the same issue. I can charge fine using granny charger at home, but have tried 4 public charging points locally and failed every time. On each occasion I can see the dash displaying a connection to a charge point but nothing actually happens. I’m using Zapmap to identify charge point but it just can’t get the charging started. I always lock the car but seems to make no difference. Is there a specific order in the connection process? Connect cable to car, then charge point then start on Zapmap? Or another sequence, or shouldn’t it matter? It’s so frustrating!
I have used Pod Point chargers and their own app and it works great every time.
Unlock your car, open charging port door, connect your own cable, then lock the car, you will also hear the cable being locked as well. Top-up the balance in the Pod Point app if needed, select the name of the pod, select A or B (side of charger, each pod has two outlets), click begin charging on Pod Point app and the car starts charging., nothing needed from the car side.
Beware that the MG iSmart app's main page might not show accurate charging status, you have to scroll down, click "EV Management", it will take a second to refresh then it will give you the state of charging, and every time you want to check the charging status you have to close the iSmart app, open it new, go to EV Management, wait for refresh and then see the charging status, it does not keep updating by itself, it just updates once then you have to close the app and reopen it to fetch new data, maybe they will fix this app later.
I have been informed that if you pull hard enough the plug can be removed, with no ‘apparent’ damage to the socket. In your circumstance, it might have been worth a try.
