Rear Nextbase camera fitting to S6.
Giller
Lisburn County Antrim
MGS6
Well This was my Nextbase rear camera being fitted, for those intending to do similar reference to my fitting the 522gw wired to the OBD port will be useful as the early parts are the same, other makes of camera are available but the fitments the same.
The dedicated rear camera from Nextbase plugs into the right side of certain of their cameras so installing is a case of running the cable to the back of the car, I found it straight forward and very easy tucking it into the headliner, door seals as before all the way back to the rear boot pillar.
Once there it can get a bit messy, you need to remove the seal from the rear boot which meets the headliner, MG use a non permanent adhesive which will pull into threads, it doesn’t need to be wiped away, that would potentially cause issues, just be aware and keep your fingers clear.
With the seals removed you have access to under the head liner, don’t move it more than you have to but you can feed the cable to the right hand cable access, initially I went for the left one but much more going through it so far harder to feed through, right much easier, I have a cable pull in the tool kit which made it very simple. Be aware, simplest way would be to remove both the top and bottom grommets, but I found the bottom would not budge so fed through the top, coating of litium grease let it fit back in place easily and maintain the waterproof seal.
From there ideally I’d have liked to remove the trim panel that runs across the boot lid over the rear wiper motor, from previous installs I know it should pop off but even with my widest trim tool it wouldn’t budge so for now cable has been fed to the central round grommet and secured with good old gaffa tape, it’s secure, out of the way, safe and invisible from the outside, it’ll have me waking up in a cold sweat and screaming at 3 in the morning, but needs must. 😝
All working perfectly, does take a while setting up the view, the mount is magnetic so lot of adjustment, works well, I’ll get some proper views when I get it out on the road tomorrow.
Watch this space…
OK, as promised screen grab of the rear view camera out put, being a video which I can't post here it's not as sharp as the original but will give you an idea of what it records. Nextbase system records dual files, front and rear which you can access, front in higher format than rear but both sync in time so handy to have I've always believed.
I have the same one, but I got Halfords to to fit it for £80. They did it the same way, to the OBD - but only after they were unable to find an AUX supply so that the camera wasn't running all the time when the car was in the airport Car Park, while we were on holiday - so now we have to unplug it from the OBD. I thought this isn't a great solution so I wrote to Halfords suggesting they speak to MG and get some help - I even gave them MG's email address. I ended up having to go to their CEO just to get a response...... they put me in touch with their regional manager;
His attitude was “get stuffed” – they don’t do “splicing into wires” and they will come and take the dash cam out and refund me. I told him I expected a big company like yourselves would speak to the manufacturer for guidance (there are, after all over 100,000 MG’s on the roads in Britain now), I was slapped down immediately with “Nah, nah, we don’t do that”. I said I wasn’t impressed with his proposals and his response was “I’m not here to impress you!”, not a sorry anywhere - just if you don't agree with us, get stuffed. I've kept it - I don't see any other option other than having the car pulled apart to get it out - then have someone else pull it apart again to fit another one.
Never mind, they wont get any more custom from me and every chance I get I'll tell people of their woeful service.
Not a surprise at all. If you want it done properly, should get a professional installer to do it. Halfords installation is no better than a semi knowledgable DIY’er. Anything complicated they won’t/can’t do.
I have made a slow start at my Nextbase dashcam install today by fitting the camera in place. Waiting for a compete dry day to tackle the wiring to OBD port. Won’t be running a proper rear camera as I don’t have the skills nor patience to do install it.
Once the Nextbase plug is plugged in to the OBD port, it is difficult to remove without a thin bladed screw driver as a tab locks the plug in place.
