Regeneration is limited please use the brake pedal.
Peacsy
London
1st Gen ZS EV which has 5 year service last week, they mentioned slight rusting on the brakes so turned kers down to 1 and tried to give them a little clean.
However since then and turning back up to 3 I've noticed when I start the car I get the "Regeneration is limited please use the brake pedal" message pop up, even though it feels like it's working once I set off?
Any ideas.
The battery level is around 90% currently, so it's not as if the energy doesn't have anywhere to go.
Our Niro gives the same warning at lower %ages than the MG, maybe its just part of the way the BMS is programmed, or just that at regen 3 it can put in a higher current that the BMS will allow.
It's odd that this has started happening since the service, as I had never experienced it previously, even when the battery was fully charged. Although I have tried balancing the battery since then, so maybe that's something to do with it? (told at service battery health was 90% and they suggested that might help).
Do you know if there's any way to monitor regen when driving?
On the MG4 it shows %age braking effort and the consumption screen 'should' show how much has been returned. Maybe a ZS owner will be able to help.
I think on this screen you will see moving arrows when you are driving, indicating the flow of electricity. Obviously I can't take a pic when I'm driving :-D
If you accelerate you will see the charge going one way, and a positive figure in the power% on the right. If you are in regen 3 and lift off the accelerator, the arrows will reverse direction and you will see a negative value in the power%.
As mentioned already, if the battery is close to 100%, there will be no regeneration. Not sure how much it needs to drop to start regerating, but I believe it does regerate at 90% on my car.
The capacity to store the energy is not the only factor limiting this function.
If the battery is cold, it will not be able to accept as much power as when it is at running temperature.
So if your battery is pretty cold and the charge is at 90%, it might not be able to accept the current the regen can put into it.
Imagine this....When regen braking you might feed a LOT of amps into the battery in a short time, if those AMPS exceed what the battery is able to take, they give you this warning so that you are aware, it won't regen brake at full power.
On my Tesla there is an icon that means the same as what the ZS EV put on the screen, I have seen this icon on at only 55% SoC on a cold cold morning (-11 Celsius).
Moderator: SoT -> SoC; I hope that's what you meant.
Any ideas.
Regen will be limited at 90% SoC i believe.. so its a fair notification.
At 90% I don't have any regen limit, it's perfectly happy in OPD.
0 regen at 100%, but comes back in slowly at high 90s, slowly increases until about 93% when full regen becomes available.
I'm not sure if there's a temperature dependency here, the battery can charge better at higher temps, but this is not about charge current, it's about state of charge.
Yes, but when the car does regen braking it actually charges with quite a lot of amps, so if the battery is cold it might now want to accept that many amps.
The charge curve indicates that at 90% SoT, under ideal conditions you can only put 20KWh into the battery, so if it is really cold that might be less and if the car then tries to put 15KWh into the battery but it is cold so can only accept 10 KWh, it will warn you.
It's pretty easy, the car calculates the max current the battery can accept, based off of SoT and temperature and if this figure is lower than then maximum the regen braking is able to put in, the car will warn you.
As stated earlier, on a cold day with minus 10c i have seen the "regenerative braking limited, telltale" on my Tesla on, even at a SoT of around 50-60% SoT.
Yes, well we don't experience those low temps here, outside temps can get down to 5°C, but inside the garage it will be warmer.
I had a feeling that Battery temperature could limit charge current, so as you say that will also affect the level of regen available.
However it shouldn't have a lot of effect on the SoC that some regen is available at.
I think you are wrong about kWh, I don't think the battery looses its capacity with low temps. At 95% SoC it can still accept 5%, but at a reduced rate when it's cold.
