Mr H
Am I the only one that feels that Reverse,Park,Drive should be Drive,Park ,Reverse on the ZS EV.
Just feels natural for me to turn to the left for drive as I do after reversing.I don't mind it TBH. My last car you had to go from park, to reverse, to neutral then to drive.
Not sure what you mean to be honest. From park you can select reverse or drive. From reserve or drive you can select neutral or park. From drive you can select straight across to reverse and from reverse you can click into drive. I find it really easy to useAm I the only one that feels that Reverse,Park,Drive should be Drive,Park ,Reverse on the ZS EV.
Its the same knob if the steering wheel was on the other side so away from you would be drive I guess.Just feels natural for me to turn to the left for drive as I do after reversing.
What I mean when I reverse of the drive or out of a parking space I naturally turn the dial to the left for drive then realise its to the right for drive. Just need to train my brain lolNot sure what you mean to be honest. From park you can select reverse or drive. From reserve or drive you can select neutral or park. From drive you can select straight across to reverse and from reverse you can click into drive. I find it really easy to use
I know exactly what you mean! Every so often I end up reversing accidentally when I meant to drive (usually when turning around in the street)
