Reversing camera
Willie
Forres,UK
Is the wiring loom the same on the Zs excite as the exclusive, if so can I install a plug in mg revering camera
This is an absolute guess, but i would imagine that you would need to have some sort of coding done to the infotainment for the camera to work if is not there as standard.
The reversing camera comes on when you select reverse, but if the car does not have the reverse camera, it should not shift to show the camera, as it would just be showing a black picture.
So a guess would be that if you were able to add a camera, you would still need to have the function enabled in the infotainment, and i bet, MG are just like most other manufacturers of today...They don't do this, as their attitude towards stuff like this is "If you wanted this feature, you should have bought the car with this features specced"
If I was you, I’d visit a good Auto Electrics place as they might be able to give you some advice and maybe a solution to your question.
I’ve been thinking about having some front parking sensors fitted to my MG5, a feature that I am used to, having had them on my last few cars. My MG dealers recommend a local AutoElectrics place that have an excellent reputation so probably your dealers might be able to recommend one for you as well.
Good luck.
I was thinking of doing this in my current Focus before I ordered by ZS. The loom on the ford has a connection on it for a camera, its just missing the camera.
The wiring looms should be the same as it would be an additional cost to MG to have 2 or 3 different wiring looms for essentially the same car, but as hmadsen said, the car would need to be coded to enable the feature.
I know with Ford you can use Forscan with an obd and it can be enabled really easily but not sure about MG's (yet). I'd assume if someone has the software it would be simple enough, or, if you know a really good mg dealer, they might enable it for you at a price and it would be quick too? It wouldn't hurt to just ask them.
On some cars enabling features is as simple as flipping (the right bit)
I came from a vauxhall and on those it was not that easy, basically everything was encrypted, and could only be unlocked with the proper code. Rumours had it that these codes only resided on vauxhall's main server and only dealers were able to request these...at a price, and a lot of features were not even possible.
Until someone figures MG coding, it is anyone's guess how they protected their software.
Many thanks to everyone for their input. I did ask the car dealer if they could carry out the retro-fit, but said they couldn't do it, they gave me a number to call an auto electrician which I will try
Through the hidden menu there is an option to activate the vision of the rear camera on the screen, if you activate it, it is black but the directional lines work and the indications of the sensors also work. I have been looking and I have not found the wiring of the camera in the rear bumper, so I think that it could be put, but it would be necessary to wire it.
Hi Jordypal, Where do you find the hidden menu
Hi! In the end I got to install the parking camera. I had to do the electrical installation to the screen and it works correctly.
Hi Jordipal, what make of MG have you got, where did you find the socket for the camera
Hi Jordypal, I removed the rear bumper from my zs excite but could not find a socket to plug the camera in, where did you connect your camera to
Hey any update on this?
I figure out what are the pins for camera but don't know where to power it, I use now after market multimedia but I don't like the settings of the safety system it's all messed
