Schuko to 3 pin adapter
Deleted member 6627
Does anybody have a link to a good schuko to 3 pin adapter for a UK granny charger? I'm sure somebody posted a good one a few months ago but I can't find the link.
If a euro granny charger is a better and safer option then I'm happy to invest a little more. It will only get used once a year though.
This is required for an MG5.... If that makes any difference.
Try this site. If this item isn't right they have others
@Gomev
I think the one you posted is the reverse of what @LongRangeDave needs! Also, as far as I can see that web site doesn't seem to have an alternative "reversed" one.
A quick check on (the ubiquitous) Amazon produced this. Clearly, anyone using it would need to be careful to NOT plug anything else into it if the Granny Charger was "active"!
CORRECTION: I think this on the toughleads site will do what is wanted!
This sort of thing is a better idea, but check it regularly when first using it to ensure that it doesn't overheat.
Schuko Euro Plug Socket to 13A 3 Pin UK Plug Adapter [Earthed]
Kenable are a reliable supplier and normally quick although possibly not over the New Year holiday.
Edit to add picture showing how it connects:
I'd have preferred a longer contact area but it is sufficient for 10A.
@BugEyed
I think what you're suggesting is the reverse of what is being asked for! o_O
As I understand what @LongRangeDave wants it is to be able to connect a Granny Charger with a UK plug to a Schuko socket! I think your linked item is to allow a Schuko plug to connect to a UK socket.
@Gomev
or this
Thanks, tough leads have exactly what I am looking for. And, yes, I am after a lead to plug my UK 3 pin granny charger into while in France.
