Screen brightnes
Weeble
Wiltshire
MGS5
Hi,
First posting!
I picked up my black S5 on Saturday but not driven it yet so it's too soon to post a review.
I've gone through the numerous set up menus without a problem except that the screen brightness is very dark. Makes the navigation screen almost unreadable. I tried to lighten it using the menu options by swiping down from the top of the screen but it doesn't seem to have an effect.
Is there a day/night time mode setting somewhere that I've missed? Or any other suggestion?
Cheers....
I've noticed the same - on my old MG5, it had an automatic setting where it switched into dark mode when the auto-headlights went on and that feature is sorely missed on the new MGS5. Perhaps MG will issue a software fix to add it?
There's a choice between light/dark themes available, and you can also independently set the brightness of the infotainment screen (swipe down from the top works well for me) and the cluster.
My only complaint is the cluster on max brightness still isn't very bright. I am pondering if a cowl would help, but shouldn't have to.
Thanks for the reply. Please can you tell me where to select the light/dark themes. I've searched high and low!
I found the infotainment screen brightness slider on the swipe down changes the actual screen brightness but the navigation map brightness appears unaffected.
BTW, Google Maps appear at their normal brightness. Maybe the answer is to stick with that.
Under Settings on the General tab, just below Cluster Brightness, it's called System Theme.
I havent had an issue with the built-in nav brightness.
drove the car at night for the first time and the screen was sooo bright. Managed to change it to dark mode but surely I won’t need to do this every time. I thought the screen would change automatically depending on day/night time driving.
From the usual home screen, 'themes' for dark or light overall are accessible by swiping left bringing up a second home screen. 'brightness' settings are accessed by swiping down. In my opinion the dark is too dark making the nav screen illegible regardless of brightness setting. The brightness setting doesnt seem to make a lot of difference on the 'light' setting. What is really at fault is the poor contrast especially in the nav screen - contrast is not adjustable.
Great car but new software seems to have introduced bugs compared with the original ZS software.
I find that Google Maps goes to night mode even on automatic during the day. On Day mode, it's fine.
Go into the settings screen, adjust your preferred brightness for daytime. Switch on the headlights, then adjust brightness for night time. Now when the lights come on you should have a dimmer screen.
None of these replies seem to be for the Driver display, but are relevant to the larger infotainment screen . I have yet to find out how to alter the backlight or brightness of the Driver’s display (colour console it’s called in the handbook) despite it supposedly being accessed via centre right button on steering wheel.
The software controlling the main centre screen certainly isn't perfect or easy to use. On 'light' theme setting the nav is ok but could do with more contrast regardless of brightness. Its too bright for me at night so I change to 'dark' theme with max brightness , which is just about ok for Nav and the glare doesn't intrude for night driving. These changes have to be done manually via settings, they dont seem to change with the external environment (day/Night). Most older conventional cars such as my Skoda Superb handle this better and Ive never had my vision compromised by a too bright screen at night. Perfection takes a long while to achieve. I have no problem with the MG's driver display except some characters are a little small for my eyesight and switching to road ahead and then the instruments. Same problem for my other cars - its age!
You can change the driver's screen brightness by going into Settings and the second option from the top is Cluster brightness giving you the options of Low, Medium and High. You can set one level with the lights off and then by turning the lights on set a different level. The car will remember the settings.
I have observed that the main centre screen brightness is not remembered.
Let me elaborate...
I set the daytime brightness, that is remembered. I set the night brightness (both cases swiped down - adjust slider).
Like is said daytime fine...bright. Night, swipe down and you see the dimmer slider is adjusted down but the screen is bright, the slightest interaction with that slider, dims down. So to summarise the slide remembers it's position, the screen does not. It's bright in the dark until you interact with the slider.
Anyone else?
Mine has been remembering both the day and night settings, except for the other night when the screen was daytime bright but the slider was at zero. Touching the slider did change/dim the screen though.
That's just made me extensively test it's reaction to light on lights off. And same Bilbo, it's remembering like yours, even cluster. But in real world when I get in and perform my usual ritual, android auto connect, reverse, indicate etc... something is triggering brightness high despite lights being on (which should command brightness low). I'm going to test one by one thing and see if I can isolate whatever is tripping it into bright high. I'll report back in a couple of days.
If you start the car in the evening the screen will be light, to set it to dark, you switch off your lights manually and on again than the screen stays dark.
