Screen
Tommysan
Midlands
Hi can someone please help me screen has gone blank on my mg zx car so can’t have radio on or adjust anything on screen thanks tom
Switch the car off, wait a while and switch it back on.
It will almost certainly return.
No this never worked it never come on this morning on way to work so it was off all day so when finished work it was still the same blank screen car is only six months old
Let's know if it works as a few on here have solved a few problems with this method, fortunately I've not needed it but if necessary will certainly give it a go
while in ready mode... (can even do while driving) ... press and hold the central knob for upto 30secinds... usually resets it self and reboots.
Foot on the foot brake, press the “ Start” button, as if you intend to drive away.
Press and hold down the silver button on the front of the info unit.
Hold it down for about 20 seconds and this should reboot the info system when the car is fully booted and ready to drive.
If this does not work, take 10mm spanner ? to the negative terminal of the 12 volt battery and disconnect it.
Leave for about 10 minutes, then reconnect the terminal and tighten down the clamp.
Now return to the car and go through the normal stat up process.
The info unit should now jump into life.
If not, you need to ring the dealer.
Thanks for that am going to try that in a minute
Hi mate just to let you know i tried foot on brakes hold button down it rebooted with MG logo but still don’t light up with anything will try battery later but thanks
ok. I think I remember doing this when I first got the car. There's something you can do to switch that screen to a blank mode, but I can't remember how I did it or how I got back out if it. (or for that matter, if I just dreamed it!) I'm in a 5. I'll have a play if I get a chance and see if I can do it again.
I have a vague memory of blanking the screen, then thinking 'oh sh1t. how do I undo this...'
I have a vague memory of blanking the screen, then thinking 'oh sh*t. how do I undo this...'
If I remove battery will I lose radio code
After you've done that, just touching the screen brings it back.
