Jam
- Jan 13, 2025
- Scotland
- ZS Hybrid+
Hi, the thread title says it all.
LiOn batteries need a little warmth for full capacity, and also don't like too much power to be sucked from them when around or below freezing, I guess it's a protective programming. In less overpowered EVS you also tend to have a little less power with a very cold battery (so in very powerful ones, but you probably don't launch every time with full power in a Tesla Plaid or Porsche TaycanFor a few days now, we have had -6 to -2 degrees in the mornings and I have the feeling that the acceleration takes a little longer with the electric drive. Is it possible that if the battery is still too cold, the power is reduced? Unfortunately, there is very little information about the structure and the exact functioning of the drive.
Thanks for this.I find turning the heater on will automatically turn on the engine as that is where it gets its heat.
If you just use the heated seats and steering wheel it will stay in EV mode much longer, at least untill your windows steam up.
I tend to turn on the heater when the engine kicks in to charge the battery and then turn it off as soon as the car has heated up/windows are clear.
This almost always turns the engine back off within a few seconds.
Currently averaging 46.3 over around 600 miles and still going up.
Individual trips are in excess of 50 mpg (and occasionally up to 70+) so still room for improvement.
Regen 2 and normal mode.
Should also add, I fill up at costco with premium petrol.
It's also cold, so I would expect this to go up in the summer (at least until I have to turn on the AC).
