Showing internal Temperature
Ruislip Resident
Ruislip
Not an MG
On the MG app if you run the check the car status function, amongst other things it shows the cars internal temperature. Is there a way you can see the internal temperature on the infotainment screen or the drivers screen. Not the external temp or the temp you have set the car to heat to or cool to, but what the actual internal temperature is at that time.
Once it reaches it then yes, it will be whatever you set. But if I have not turned it or the fan on, is there a way the actual internal temperature at that point can be seen on the infotainment screen or the drivers screen. It can clearly be measured as you can see it on the app if you run the vehicles status function.
The interior temperature is shown on the vehicle status screen. In my experience it is not usually correct.
