Deleted member 9692
- Aug 27, 2022
Ball joint nuts can be recovered easily after removal and before fitting of inlay panel and strut retailer is supplying a new metal rod to reattach them for cheap. My question here was is it worth getting the inlay panel or leave as is.Fitting the insert may be tricky now that the struts are fitted ... looking at the video the insert is (partly) held in place with clips that fit where the ball joints are now fitted. So the struts would need to come off to allow the insert to be fitted ... which means the ball joint nuts may escape.
