SOS system not working
vulcanboy426
Ipswich
MG4 SE SR
Does anyone else have the problem of the SOS system not working on their MG4 .On a number of occasions when starting the car, we get a yellow warning triangle on the dash, and the SOS symbol is red, sometimes it clears itself during the journey, but often we have to stop, switch off the vehicle with the main power switch and start again.
What should happen? Does it patch you through to the local emergency services? Can the operator receiving the alert call the car to check? I've not got my car yet so someone has to press the button for me to find out ?
From the manual…
Page 257
eCall- SOS Emergency Assistance In an accident, your vehicle’s eCall– SOS Emergency Assistance can either be triggered manually or in severe cases automatically upon detection by vehicle’s sensors. The eCall service is a public service of general interest and is accessible free of charge. The emergency call centre will establish verbal communication with the vehicle occupants in order to understand the extent of the emergency and the level of assistance required. If verbal communication is not achievable an attempt will be made to send the following vehicle information message to the emergency call centre. The appropriate emergency services will be deployed to the vehicle’s current location if known. • Current time, location and direction of travel • Vehicle Type • Vehicle Identification Number (VIN) • Whetherthecallwasautomatically or manually initiated • Vehicle Category This system will ensure that your personal data is securely protected. It is designed to ensure that it is not traceable and other external systems are not able to gain access. When the eCall triggers, the system will only transmit the data information to the relevant public safety answering points designated by the respective public authorities of the country on which territory they are located, which will receive and process your emergency call request. The system will retain data locally within 13 hours of triggering. You have the right to access the data information stored in this system, and to request the rectification, erasure or blocking of data information that does not meet the requirements of the regulations. When you think your personal data is infringed, you have the right to complain to the competent data protection authority. For manual activation, press and release the SOS button in the overhead console for about 1 second to activate an emergency services call. A single beep will be heard when the eCall is triggered and a message will be displayed on the vehicle’s message centre and entertainment player. The entertainment player will be muted whilst the emergency services call is active. Manually triggered emergency services calls may be cancelled by pressing and releasing the SOS button again within about 5 seconds of the initial press, and the messages will be removed.
Page 258
The emergency services call (eCall) system will perform a self-test when the vehicle is powered ON. During a Self-Test the emergency services call (eCall) LED status indicator on the SOS button will flash quickly until completion. The LED status indicator will illuminate permenantly if no system faults are present. The LED status indicator will be extinguished or flash slowly if a fault is detected. Faults detected during the self-test will be displayed on the vehicles message centre. Note: The operation of eCall- SOS Emergency Assistance relies on cellular coverage and may be affected by signal outages or low signal strength. Note: The automatic emergency services call (eCall) function may be disabled by a local MG Authorised Repairer upon request. Note: It is strongly recommended the eCall function is not disabled, any action requested by the owner must be accompanied by a signed request.
My daughter pressed it once. Immediately a voice came over the speaker to ask if I was ok and if there had been an incident. They were great when I said it was a mistake. But it’s comforting to know it works anyway
Had mine flash up the warning for the first time yesterday, seemed to clear itself without a stop/start cycle so assumed it was just a lack of phone signal where i was driving or standard MG software glitch.
Was the first time I noticed the green LED on the SOS button flashes on start up until it has booted up that system then the LED is constant when active
I have the same here at least twice an hour. It's In again in 4 weeks time for the day, so MG technical can give some input.
I'm not too bothered about the feature working, but a bit worried that I'm beginning to ignore all warning popups now.
    Votes: 943 77.6%
