Styling
I modified my aerial. :giggle:
Enyone with some pimped up mg’s on here?
Not highly pimped….. dash board mat (keeps the heat off dash, also stops dash reflection on dash cam.)
Chrome type Wind deflectors and mirror covers.
Tints,….scuff plate front and rear
I bought this one, expensive, but has a very OE feel to it and the internals are properly designed to maintain good reception despite its short length (apparently!) My reception remains good with it.
What’s wrong with the one fitted to the vehicle by MG? I’m struggling to see what youve gained by changing it.
I've got "18's, mudflaps, & a short antenna! Auto dimming mirror inside. That's as pimped as it gets.View attachment 4822
Hi Paulie,
I love the look of your wheels!!
My MG ZS EV arrives in NZ in a few weeks and I'm looking to upgrade to 18's also. May I ask what the wheel dimensions are, so the rim size (18), width, and importantly, the offset?.
Also can you give me your new tyre size?
Thanks,
Bruiser
Hi Paulie,
Thanks,
Hi, My wheels were 18" x 8" Audi A4 sport (2017)
The offset is 40.
They fit perfectly and you have the option of 225/45, or 245/40 tyres to keep the radius about right. I'd recommend the former, ride is better.
When fitting Audi rims, you need Audi to MG spigot rings I forget the size, but easy to look up. If you fit VW rims, the centre bore is correct to start with. All VAG group wheels use a radius bolt rather than the flat taper MG use, so be sure to change to the correct bolts when using oem VAG stuff.
