TPMS failure. where is the Tyre Pressure Control Module 10932806/01?
Member 12371
Stafford
MG5
I need to replace the tyre pressure sensor unit or find out if its power is connected, Yes I should be looking for its fuse I suppose 1st.
I have a new MG5 tyre sensor detector and configuration tool on order so I can reprogram all the sensors to the correct position on the car. Wheels being rotated confuses the system!
If the Fuse turns out to be OK I then need to check for power on the unit itself. where the hell is it? 22 plate MG5.
Any help much appreciated.
Once I have the tool I am happy to reconfigure anyones wheels in the Stafford area.
I have 3 of these in use as Taxis. 77k 126k and 200k miles and all good... except this one on 126k miles.
Keep smiling ;)
