TPMS Fault Consult Handbook
Nanu
Admit Israel
Hi
The car ia a MG EHS PHEV.
I am receiving the warnings shown on the attached images.
.Pay attention to imagine "TPMS-02". No pressure or temperature are shown for any of the four wheels
Please help.
TIA
Nanu
Depending how old the car is the battery in the sender may have run out or there is a fault on the system. The quick way to find out is go to a tyre place and as if they would check it for you with there reader. Have checked your tyre pressures.
Car age is 1.5 year. The pressures are OK. Front 2.5 Bar rear 1.2 Bar.
Check out your pressure in the handbook on on line at My MG or on the door as those don’t sound like the correct pressures. After that if the readings don’t come up try a tyre place.
To have all sensors display nothing says to me there is something upsetting the transmissions to the car or the car itself.
I had similar on a different car which also took out the remote central locking. Is your fob working (i.e does pressing unlock ON THE FOB work?). They transmit on the same frequency as the tpms.
Here in Malta dealer sticks rigidly to the manual.....and so do I:
PHEVWheels Unladen Condition Cold
Front Wheel 250 kpa/ 2.5 bar/ 37 psi
Rear Wheel 250 kpa/ 2.5 bar/ 37 psi
'Sender' thankfully has not stopped working yet. But at least I am aware of the possibility.
Is there a way of resetting the TPMS fault consult handbook error without going to a dealer?
I've pumped all the tyres to the correct pressure and drove for a week.
I've done a factory reset and restart of the infotainment system.
Looks like the sender unit has stopped working as I get "--" on all 4 wheels on the dash.
It could just need a reset or it might be a loose connection.
It resets automatically when you drive the car for say 10 minutes.
I had this fault on my Petrol ZS Trophy. All 4 tyres were pumped up and even checked at a garage.
I took it to my dealer and the TMPS Module needed to be replaced (Didn't have one in stock so had to take it back). Took a couple of attempts to get it done as the sensors in the valves didn't get picked up my the module.
If car is over a year old just go to a tyre place first as not under warranty any more.
This fault has just happened on my 2022. Dealer says its a common fault, not to worry about it, and my car is booked in for a warranty fix in 10 days.
