TPMS fault
JackP400
Eastbourne
Hello all,
Has anyone had this issues with there ZS EV the TPMS sensors keep dropping out on the rear wheel?
After several miles it clears and then comes back on again.
My front left one is permanently reading high for some reason.
I have just increased tyre pressure to suggested 33psi on the car info plate. I have never checked the pressures since taking delivery from the dealer back in early June I found all the tyres were around 25psi.
TPMS warning has now gone away for good hopefully.
Sorry to say not as a standard procedure. Always relied on dash telling me something is wrong.
Just an update, i didn’t manage to get round to do the tyres before the weather got warmer, for some reason once we got above 5 degrees on Monday the system warning went out and is now showing normal tyre pressure- guessing it definitely was sub zero temp that caused it. Thanks again all
Thanks Didn’t get to do it before the warmer weather, looks like it was just a glitch and once got warmer it reset itself- phew
Do remember that you will get further on tires inflated to 2.8 rather than 2.5.
It was not a glitch it was low tyre pressure below the threshold now it's above the threshold as it a bit warmer but your tyre will still be below recommended pressure of 2.8(41psi) cold if your driving to a pump you probably want to add a bit more
Yes thanks again all, checked and tyres were all sitting at 2.5 bar , I’m guessing this was dealer setting as only had car since October, have done as suggested and all now on 2.8 bar and car feels also better to drive. Thanks again all and Merry Christmas
