Turning on the Radio - but Stopp the Engine
Zino
Germany
MG HS PHEV
Good morning from Germany :)
I've my EHS since yesterday, and I noticed a few "strange" things, about I was reading here, too.
But did you also have the problem, when you just want to sit in the car, don't want to start the engine but wanna listen to the radio - it is not possible. After 30 seconds or 1 minute, the Radio will turn off.
So it's not possible to go to an Car Cinema, by not turning on the Engine?
Youve maybe a solution for that?
Thanks a lot,
Zino
Hello
if you do not press the brake and press start button once, this start some systems and the radio will come on. After around ten minutes the car will switch its self off. If you repeat the above then press the start again not pressing the brake then you will find that the day running LED lights will come on and now the radio will continue to play and the car will not turn its self off after ten minutes. When in this state if you wish to drive off you then press the brake and press the start button and the car will come to ready, if you wish to turn the car off then press the start button and the car will shut down.
