prospectivebuyer
Going away this week and taking my granny charger to plug in when I get there. Is using a normal 5m indoors extension lead a stupid idea for outside for 1 night?
May be stating the obvious but with the current weather do watch out for rain on the cable if outsideGoing away this week and taking my granny charger to plug in when I get there. Is using a normal 5m indoors extension lead a stupid idea for outside for 1 night?
The current is a constant 10A in the UK.It should be fine. Indoor cables are often of a lighter guage cable, which may warm a little with constant 8amp draw, be mindful.
I take it you have asked permission to charge the car overnight? There has been some arguments in the news recently about some rental property owners objecting to EVs charging up using their electricity.Going away this week and taking my granny charger to plug in when I get there. Is using a normal 5m indoors extension lead a stupid idea for outside for 1 night?
Okay, supplied charger in Australia is 8aThe current is a constant 10A in the UK.
they’ll never knowI take it you have asked permission to charge the car overnight? There has been some arguments in the news recently about some rental property owners objecting to EVs charging up using their electricity.
I was thinking about putting it under the car out of the way of rain etc , but maybe a plastic container is more suitableShould be okay as a one off situation.
Check on the cable rating, it is printed on the outside sheathing.
It needs to be no less than a cross rating section of 1.5mm.
Larger ( 2.5mm ) is fine, but not any smaller than 1.5mm.
Some of the cheap windup ones are only rated at 0.75 / 1.00mm - NO GOOD !.
This size flex will over heat and is dangerous.
Okay for your Xmas lights etc but that’s it.
If the cable is in good external condition and it gets a little wet, there is little risk here.
It’s the socket outlet that your Granny lead plugs into, that is the vulnerable part that needs to be protected from the rain.
Try and keep the socket outlet off the ground and as a temporary measure, do you have a large plastic storage container that could be used to put over the socket outlet to shield it from the rain ️ ?.
If you intend to use a socket outlet externally, then it should be suitably IP 55 / 65 rated.
This rating covers both dust and water ingress.
As other members have said, monitor the heat being produced at the three pin plug that you are using to power your extension.
The plug top WILL get warm to the touch, which is completely normal, but if it gets mad hot to touch, then stop.
The plug on the charger is unlikely to get hot because it carrying a heavy duty plug and cable.
Placing it under the car will help keep it dry of course, but in the very very unlikely event that the unit developed a fault, under the car may not be the best location then .I was thinking about putting it under the car out of the way of rain etc , but maybe a plastic container is more suitable
they’ll never know
Another angle is if they have not specified anywhere about the usage of electricity for charging then why can’t I ? As I’m renting the home for 3 days I expect to use it as I would my own home over that time period. Maybe owners need to be a bit more savvy if they don’t want people doing this as it will only happen more often going forwardsMaybe not, but they may check. Considering that the cost of the electricity isn't likely to be great, it might be worth offering them the cost, if only to avoid creating ill-will against future EV drivers visiting.
I usually say the car draws about the same as a fan heater running continuously, maybe between 50p and 55p an hour. You'd probably need to charge for 18 hours to bring it up to a tenner.
Yep that's the right outlook, at home you would pay for your electricity (I assume) and therefore here you should pay too.Another angle is if they have not specified anywhere about the usage of electricity for charging then why can’t I ? As I’m renting the home for 3 days I expect to use it as I would my own home over that time period. Maybe owners need to be a bit more savvy if they don’t want people doing this as it will only happen more often going forwards
So when you use an air bnb you normally give them an extra tip towards the electric for using the shower, oven and watching the tele?Yep that's the right outlook, at home you would pay for your electricity (I assume) and therefore here you should pay too.
